Hi there!
New TeamViewer user here, so forgive me if I am unaware of specific functionality that may exist!
I have a series of machines that I already access in TeamViewer. I want to monitor if the SQL server agent is up and running. I can do this remotely by hand (https://stackoverflow.com/questions/11632849/how-to-check-if-sql-server-agent-is-running) but I want to automate this and have TeamViewer monitor the status of the SQL server agent across my servers.
Is that possible?
Thanks in advance!
with the Monitoring & Asset Management you can create a monitor a specific service or process (like the SQLAgent service you ask for). So if you activate the licence of teamviewer Remote Management your problem will be solved.
See what's new at TeamViewer
