Can you either remove a connection from Recent Connections section or clear the entire REcent Connections list? I see you can delete, but that acts like it will remove the connection completely, so I didn't try it.
Hello @mether,
Unfortunately it appears that there is no way to easily clear the recent connections list. This article says "It is not possible to... delete the group or contacts". I also tried within the app itself and checked all options and found nothing.
That would be a good request to place in the Ideas and feature requests area.
Cheers!-Josh
