new policy "hear my audio/sounds" for incoming access control connections
I would like to ask for a new feature. There should be a policy where I could forbid the other PC hearing the sounds of my PC while being remote controled (incoming connections)
There are a lot of different policies but nothing for audio. Please add that one.
    JeanK Posts: 5,149 Senior Moderator
    Hello @Gutriko,
    As an alternative, I could suggest the following:
    You untick the box Play computer sounds and music in your TeamViewer settings under Remote Control.
    And then, you export the setting via the .tvopt file and import this file into all the PCs that need to get this setting applied.
    I hope this could help. ?
    Stay safe and sane! ?
    French Community moderator
    👉 Have you already tried out the new TeamViewer user interface? Do you want to give feedback? 👈
    ✅ GREAT - Go Ahead!
  • Gutriko
    Gutriko Posts: 4 ✭✭
    No this does not help unfortunately, Your proposal would mean that I need to rely on the other person to disable the sounds on his Computer. I want to block the other person from hearing my sounds, not just ask him to stop listening. It's like you ask someone to stop eavesdropping, I mean does it even make sense?
