I have a client computer that appears off line in my list but isn't. I can type the client id number in and it connects just fine.
Have seen this a couple of times and it is usually a dns problem on the client side that is throwing the teamviewer client off. Like check if the client side computer isnt running on faulty static dns ip settings for instance.
Thankyou very much for your input. Solved my problem.
See what's new at TeamViewer
