Hi @Joe_Grouse,
When you activate your two-factor authentication (TFA) with your TeamViewer account, you need to use a special authenticator app on your mobile device that can generate the required security codes for you. You can deactivate TFA if you don't want to use the security code. For more information, please refer to
