I've been trying to establish unattended access to a relative's Samsung Tab A from my Windows 10 machine.
If a plugin is available for your device, the device will prompt you automatically to download it.
If there is no prompt, it means there is no add-on available for your device.
Is there a plugin for the Tab A?
I couldn't get unattended access to a relative's Samsung Tab A from my Windows 10 machine
Hello @Edrichstl,
Yes, sure! What issues/difficulties are you having?
