I downloaded the TeamViewer Management Console but do not see an option for a remote session.
I made the connection using Host. I can see the Chromebook's screen but I can't control anything.
Hello @BSSJASTeam,
For Chromebooks on the receiving side, you need to install either the QuickSupport for Android or the Host for Android.
To make outgoing connections from a Chromebook, you need to install the TeamViewer for Chrome OS app.
