I'm getting calls about the latest TeamViewer advert having what appears to be a white X on the white background. The end users don't realise that they can close the ad by clicking on the top right hand corner.
Very annoying!!! 😡
Hello @AlexFogerty
Thanks for the feedback.
All TeamViewer in-app adverts should have a visible option to exit the advert.
If you can PM me a screenshot of the advert that is affected, we are happy to forward the issue internally.
Thanks in advance.
