As suggested in https://community.teamviewer.com/English/discussion/75157/teamviewer-not-working-on-fedora-31, I am using teamviewer as
QT_QPA_PLATFORM=xcb /opt/teamviewer/tv_bin/script/teamviewer
in my local machine. But it stii dont allow me to create remote connection or view remote connection created using `Gnome at Xorg`.
TeamViewer 15.16.8 (RPM)
Fedora 34
Gnome 40.
Is the daemon started/enabled?
Try `sudo teamviewer daemon enable` then try again, maybe while installing the script didn't succeed enabling the service it need for remote connections.
