During remote control, the color deviation of the screen display is too serious. Mac connecting to Windows. The client is the latest version. The attachment is a screenshot of the desktop display on the mac.
I have the same problem, but curiously if I send a picture of the deviant colour screen to my partner and then view that on the TeamViewer screen it is OK - weird or what???
Any update on this? Of course turning of HDR works... but that's not really a sensible long term solution to turn off HDR every time you use Teamviewer and then turn it back on.
This has been going on for years, can you guys not fix it? I use various remote access software for various professional and personal uses and TV is the only one that hasn't fixed this.
Hello @futandrew,
You might look at this thread from last year:
and especially at this answer that has been flagged as a solution:
I hope this will help.
