When I connect to the remote host the time of that PC changes. (2h delay)
Is there any option to avoid that?
Thank you in advance.
Hello @begalvi,
I'd like you to try that out on another device, preferably the same operating system like the one you're facing the issue on.
To give you a couple tips on how to hopefully fix that issue already, please do the following:
There could be an issue with your time zone settings. To fix your time zone in Windows 10, right-click the system clock in your System Tray in the bottom-right corner of the screen and select Adjust date/time.
You can also go to Settings → Time & Language → Date & time.
In addition to that, I would like you to check if your windows time is out of sync. To fix your synchronization, go to Settings → Time & Language → Region, then choose Additional date, time & regional settings from the right side.
This will take you to the old Control Panel interface. Under Date and Time, click Set the time and date, which opens another window. Switch to the Internet Time tab, click Change Settings, and you can change the Server if needed.
Sometimes updating your BIOS can also fix this issue.
Quite some information, but I hope it helps. Don't hesitate to let me know if you need further help.
Justin
See what's new at TeamViewer
