We use teamviewer to remote into a lot of digital signage, security camera monitors, etc and everytime there is an update or bugfixes applied teamviewer has a popup on the device that will stay until I remote in and close it. How can we stop these from popping up?
OK sorry, that sounds like something that Teamviewer has blocked from changing due to it essentially being a free version on your host machines (even though you pay for the license).
That works great for the host device but since clients are set up for Unattended Access and you're not actually logged in then that option is grey out. Hopefully I can find a reg setting or something that can be changed. This is ridiculous.
OK So this might be what you're after. There is a setting buried deep in the menu's that should turn off any and all advertising from TeamViewer. To get to it, you need to click on your account at the top left of the main TeamViewer window, then click on the cog symbol on the far right of the screen that appears and then select the option to edit profile. In there go to Advanced and scroll all the way to the bottom and you'll see a little check box that says 'In product marketing messages'. Uncheck that box and then confirm the message that appears from TeamViewer and you should be good.
