I succeeded in connecting to my remote device. But now I receive Error Code: waitingforConnectFailed
I solved my problem. The device is a Raspberrry Pi4 running linux raspbian. The problem comes out when the display is not connected to the device. You have to force hdmi_force_hotplug=1 in the config file in the boot directory. Then with raspi-config set the default display option and use legacy drivers. Then setting the boot to CLI mode you can succeed in having a stable connection.
Hello @Monozuk,
I recommend restarting the TeamViewer service on your computer.
If this does not solve the issue, you will need to restart the TeamViewer service on the remote computer as well.
We explain how to proceed right here:
Let me know if this helps! 🌻
