Where is my TeamViewer ID and my password?
Hi @Mira_grace1973 and @nokulinda
Thanks for reaching out and welcome to our Community!
You can find your TeamViewer ID - in most of the cases, a TeamViewer ID has 9 or 10 digits - on the Remote Control tab of your TeamViewer full version.
The password is visible right below the ID:
If you are using a different version of TeamViewer - e.g. a QuickSupport module, the look and feel is a bit different. In this case, comment here and provide some information about your setup so that we can help you in the best way.
In any case, I found you an article that helps you get started: What is a TeamViewer ID?
Thanks and have a great day,
Esther
i need id and password fo teamviewer
