Can anyone please advise how to connect to my pc at home from my tablet away from home?
Hi Harry!
Sure thing!
First of all, you need to download the TeamViewer Remote Control app on your tablet. You´ll find the links here: Supported operating systems
And your PC needs the full version or the Host module: Download TeamViewer
Now - make a test connection and set up unattended access on your computer. I recommend Easy Access. Best practices for secure unattended access
Make another test connection so that you understand how it works. Do not turn off your computer and let TeamViewer run as a service in the background.
Hope that helps,
Esther
