When using TeamViewer on a Macbook to remotely connect to window or ubuntu, the character ‘c’ is automatically filled at the position where the cursor appears [computer is not controlled].
Hello @hongbo_zhu,
This sounds odd...
I would check if all TeamViewer versions you are using are up-to-date...
Let me know if updating fixes the issue! 🔄
/JeanK
Thanks, updating fixes the issue 😁
