I have a requirement where TeamViewer.exe needs to be started from command line using the -i parameter. My question is to know if there is any provision to pass the user-id of the teamviewer account in command line.
Hey @AlbertoC71,
use System.Diagnostic.ProcessStartInfo with Argument parameter set.
Check also with and without using UseShellExecute.
Hy, If I use this command processo.StartInfo.FileName = "C:\Program Files (x86)\TeamViewer\TeamViewer.exe" without -i xxxxxxxxx --Password xxxx" it works correctly !!
Hi, I tryed to insert this command into my windows applications (Vb.Net):
Hi there!
I'm configuring a TeamViewer package to install silently.
Can I use the same parameters for the TeamViewer_Host_Setup.exe?
Many thanks in advance,
Fabrizio
@Esther wrote: Hi @Ginu_GopinathI hope this article will help you:Are there parameters to start TeamViewer?All the best, Esther
Hi @Ginu_Gopinath
