How do you uninstall the newer TeamViewer host via command line since it no longer has the uninstall.exe included in the installation folder?
You can just use:
msiexec /x "{PRODUCT_CODE}" /qn
$productCode = "{PRODUCT_CODE}"
$arguments = "/x $productCode /qn"
Start-Process -FilePath "msiexec.exe" -ArgumentList $arguments -Wait -NoNewWindow
Intune does it automatically but you can get Product Code from the TeamViewer_Host.msi (using Orca under Property).
If in windows land, you can use WMIC to do it. Similar to the following
wmic product where "name = 'Teamviewer'" call uninstall /nointeractive
Same question here....glad to see it's unanswered after over a month....
See what's new at TeamViewer
