Hello
I have a lot of machines that I need to grant easy access to. Is there any way to disable the email confirmation part? Can't see it providing much security
Hello @RGNR,
Yes, there is a way to disable the e-mail confirmation part.
If you enable Two-Factor-Authentication on your TeamViewer account, you won't have to confirm the device via e-mail.
It will all run through the Two-Factor-Authentication application. 😎
Here is a guide on how to enable it:
/JeanK
