When I connect to office computer from remote computer, the screen is too small to read. How do I make it fill the screen?
Hi @DaveShaw,
Thank you for your post !
When you are connected to the remote device, you can adjust the scaling and screen resolution as shown below:
You can switch to full screen as well to make it easier to read.
Let us know if needed,
Jennifer
