With windows 10, I could automatically connect. Now I can't. What should I do?
Hello @_max123 😃
According to Microsoft support webpage you can find it on the Settings → System → Activation
You can read more on their page:
I hope this can help you get the issue resolved 🍀
Carol
Where would I find the S mode?
Thank you.
Hello @_max123
Welcome to the TeamViewer Community! 😃
If it's a new computer, you may need to redo the steps to set up easy access. The steps you can find here:
👉 Also, If the new computer came with the S Mode turned on, you may consider turning it off since it can block remote softwares like TeamViewer.
Let me know if you have further assistance 😊
See what's new at TeamViewer
