Is it possible for two users to use a stand-alone application at the same time using TeamViewer?
Hello @Zaheer_Ali27,
Good to see you posting again!
A user (@iSkills) replied to your question a couple of months ago:
Did this answer the question you asked?
/JeanK
@Zaheer_Ali27 I'm not quite sure if i understood your question correctly.
Correct me if im wrong but, are you asking if device A can access device B without any teamviewerID/Pass if they are both under the same account?
If so, the answer would be yes.
As you can see in the image below, I have registered my homePC and work laptops to my account so that I can access it without needing anyone present IN front of the target device. (This can be changed so that someone needs to confirm the connection from the target device)
Also, multiple connections are possible as far as im aware.
At my place of employment, my boss wishes to purchase the Team Viewer license for himself myself, being his employee. There is one plan that allows up to 3 devices to use Team Viewer, so my question is can my device and my boss's device use Team Viewer from the same account at the same time and connect to each other to work?
