I'm stuck here (see screenshot) - any suggestions? I tried turning my phone, and I tried restarting teamviewer.
What I'm doing: remote controlling my android phone. Or trying to, anyways.
Thank you - I've checked, and there are no specific issue reports regarding this device.
I would suggest reinstalling the QuickSupport/Host on your mobile device.
It's an LG Stylo 4. Android version 8.1.
Hi @ztyo,
Yes, I meant on your phone settings. Hmm, that's strange.
Could you tell me what is the exact device (brand + model) you are using?
Hi JeanK- thanks. You mean on my phone settings? I tried doing both. No change, either way.
If you mean in the TeamViewer settings, I can't find where to set that.
Good to see you posting again!
Just a quick question - did you set the orientation on "auto-rotate" or did you enforce it?
/JeanK
Bump - This is unusable for me now. I'm stuck in landscape mode inside of a portrait view See screenshot in first post.
