We bought Team Viewer 11 Premium license in 2016 year.
How I understand it. That is lifetime license ?
is it correct?
And if we not upgrade to newer version . Then we can uses it ?
I have a lifetime Teamviewer 12 license with only about 10 endpoints. It works great and I don't want a subscription for obvious financial reasons. I did however start having to remotely administer a Linux machine that will only use Teamviewer 15. Can I add it to my existing license if I use another laptop with Teamviewer 15 installed? The "buy a license" nag message really bothers me and I don't wont the endpoint to ever see it. Its for an elderly remote friend.
Thanks...
Bill
Hello @Eriks0403,
Great to see you posting for the first time! 🚀
You can use the TeamViewer 11 Premium only by having TeamViewer 11 installed on your devices.
You can install it from here: Previous Versions of TeamViewer | 11
If you want to use the latest TeamViewer version, you will need to upgrade your license to a subscription.
Let me know if you have any questions! I'll be happy to help you further.
/JeanK
See what's new at TeamViewer
