Remote with no monitor
Need to remote to a client with no monitor. It is connected to an 85" tv being used as a monitor. It is shut off to conserve energy while I remote in at night. So as expected, the computer sleeps or whatever until it can detect a monitor connection. I read I can get around this using windows remote desktop but I don't feel that is an option. I understand for me to auto-access using windows remote, I would have to be on the same network. That it cannot be set up to work if I am not? I did search the forums, so if this has been addressed before then I blame my inability to use the correct search terminology. Ultimately, I want to see if anyone knows of a type of "keep alive" program or setting that will allow me to remote in without the monitor on. Thank you ( I don't know if I've even chosen the correct category or not as I am not so much a technical person.
Hello @FosterWorm,
Welcome to the TeamViewer Community! 🚀
As long as the system is not turned off, it is possible to remote control headless systems.
Please find more information here: Use TeamViewer on headless systems
Let me know if you have any further questions! I'll be happy to assist.
/Jean
