The Password under my ID is not appearing. What could possibly be causing this to happen?
Thanks.
It is working today. Didn't do anything different.
Hi@aldrozd,
Thank you for posting in the TeamViewer Community!
The password display might be related to the settings on TeamViewer. Can you kindly check the Password strength and see if the setting of No password is applied? Check the screenshot of the path on checking the TeamViewer options:
Would you mind posting again about the update on your side please? Thank you in advance!
See what's new at TeamViewer
