this is the problem i am having
it was working fine last week .
this week i could not use team viewer .
i tried many times reinstalling but still same out cast
just no go same thing comes up ,like as above picture
can someone help me out
I recently got Windows 11. I have it, installed Teamviewer 15.39.6 64 bit. Can you check if the path exists?
%ProgramFiles% in Explorer -> Teamviewer/Teamviewer.exe and Teamviewer_Desktop
Do you use any programs that are (supposedly) supposed to keep your Windows clean? Could it be that such cleaning tools were accidentally removed by Teamviewer?
If the path is missing, I'd say you'll probably need to reinstall to fix the installation.
Hope I could help!
See what's new at TeamViewer
