Hi all!
I have a problem to connect with new UI to my network devices over IP instead ID.
When I try to type in the IP, my input is auto formatted after I hit ".".
Bevor "."
After "."
Does someone know how to connect over IP with new UI?
at the moment you cannot connect via IP address at the new interface , you need to revert to the old interface.
the answer is here :
https://community.teamviewer.com/English/discussion/128325/on-new-version-of-team-veiwer-why-cant-i-connect-to-a-lan-ip-address#latest
Will this function be available again in the new UI?
New UI does not support LAN connections yet.
Same here. :(
See what's new at TeamViewer
