Anyone have any suggestions to get past the "Request for permission" screen when trying to add the TeamViewer connector to Intune? I've tried to add it multiple times, but every time I'm stuck here:
I can't get past it.
Thanks!
~ David
Anyone resolved this ? It is anoying. I tried several Windows PCs, Macs and no luck.
Hi, i had the same problem on mac i used different browsers but nothing worked.
When i tried it on windows pc it worked for me.
I'm referring to adding the connector to Intune, so it's not even getting to the point where TeamViewer is added to the devices, so UAC isn't part of the equation yet. It's just connecting Intune to TeamViewer at this point, so no program is involved, just backend connections.
I'm trying a recent MSI installer through a different deployment solution and upgrading from an older version gave a UAC prompt on the user's screen, even though the update is run hidden through an administrator account.
Upgrading a recent MSI install to the same recent install or when uninstalled doesn't seem to have this behavior.
EDIT: it may have to do with the Teamviewer Service not shutting down properly and being forced ? I had one that was stuck as "stopping".
I've got the same issue. Looks like no one has a solution to it.
