How do I connect to another device?
Hi @realber,
Thank you for reaching out to the Community!
Depending on the use scenario, there are several ways to initiate a remote session.
To begin with, we would suggest checking the following article to get an overview: Get started with TeamViewer Remote
If you prefer to access a remote device without confirmation from the remote side, unattended access is also available.
Kindly return to this thread, if you have any questions using TeamViewer.
Akiho
