Hello
After recent upgrade, a few of my connections havent saved the passwords so i have to key it in each time. Before i could right click and save it in the settings but now this option isnt there
any ideas?
It appears that they have removed the ability to save the client password on the Classic View.
The only way around this I have found is to switch to Classic and then simply right click on the computer, Properties & change the password & then change back. When I did this, I realised how easy Classic was so I've decided to remain there. I don't think there is any way to do this on the New Interface, a massive failure / omission from TV as this is a very simple yet essential task.
I have found the same thing. Version 15.44. You used to be able to save the password for the remote computer by right clicking the remote unit and selecting it under Properties. Now all properties does is show the description of the remote unit. How do I now save the password for the remote connection????? PS I also think the new interface is terrible. I have tried it but the layout and navigation is illogical and just doesn't make sense.
Since you don't list your version for the purpose of this answer Ill assume the "New Interface". I couldn't find it either. But if you click on your username (top right-hand corner) and "Go to Admin Centre) you can enter a password via the web browser interface. Of course you'll need to select the device and edit.
Like many still working my way through the processes myself.
