[Logs removed as per Community Guidelines]
Hi @rocolex,
Thank you for your post!
Regarding the compatibility between Windows and TeamViewer versions, it seems that only TeamViewer 15.22 and higher versions are compatible with Windows 11:
Learn more here: 📄 Supported operating systems for TeamViewer (Classic)
The incompatibility of your OS and TeamViewer version could cause the issue you are facing.
If you have any other questions, let us know!
Jen
