Tried to connect my iPhone to an Android but once I clicked any app the screen would just turn white.
For the white screen issue when connecting iPhone to Android, try restarting both devices and ensure they're running the latest software updates. If the problem persists, check compatibility settings on the Android app, and consider reinstalling it. If issues persist, consult the app's support or forums for device-specific troubleshooting.
