Trying to provide support to an Android mobile and the user is prompted with 'DENY ACCESS' and 'ALLOW', however the 'ALLOW' option is greyed out.
The user I am supporting (my elderly mother, far away) is experiencing this problem. I have uninstalled Quicksupport and reinstalled it but this does not resolve: "Check" is still greyed out. Thanks for further suggestions
Not sure if that is going to help as there are 2 devices that are experiencing the exact same issue. I think prior to the option of 'A single app' & 'Entire screen' there wasn't this much issue with connecting to an Android device.
Hi @ManiVohra,
Thank you for posting in our Community! We're happy to welcome you!
As a first step, we would suggest to uninstall and reinstall the TeamViewer QuickSupport app on the remote Android.
Would it be possible for the remote user to do this?
Once the app will be installed again, please try to establish the connection and let us know how it goes!
We will await for your reply.
Jen
