Can I install Teamviewer Host after we've installed the Teamviewer remote control app and Quick support on the remote device
I haven't tried it lately but.
Via quick support on the remote PC, click on Files and Extras, select, Install TeamViewer remotely and select Install TeamViewer Host. TeamViewer will shut down briefly and you should be able to access via TeamViewer Host.
Alternatively, create your own host locally and configure it. I am using the "New Interface". Select Admin Settings, Custom Modules, Create custom module, Host. During this process you will see your permanent link.
I bookmark mine so I can resend with ease. Although you can always return to this module to retrieve the link. Select your custom host, click three dots (right of screen) and copy download link.
