I know there was previously an issue that kept lists from being alphabetized correctly that was fixed, but the same issue appears to be impacting the new(ish) devices dock.
Is there any way to easily alphabetize this list as well?
I also have issues with alphabetical order within the Device Dock. Works fine in the main client Devices column
