Hi
We are unable to Finalize Device Migration
Following are the random error message
Please suggest
This absolutely worked with the new interface. Thanks, Hamid!
Hello everyone, I think i have a solution for this,
I came accross this promlem today while trying to migrate also.
What i did was:
1- Go back in to your desktop software
2- I switched to the OLD interface (maybe can be done with new interface also, but i havent tried)
3- go into the UNKNOWN group, that's the PC i was trying to migrate was (in that GROUP/FOLDER)
4- right click on that particular PC you were trying to migrate and click DELETE
5- go back into your web brownser and refresh the migration page.
6- You PC/Machine should now be fully migrated.
I hope this works for you as well, All the Best.
Hamid.
Same problem. And I see in typical TV fasion they have not replied to share a fix with their users.
Still, the problem has not been solved. Does anyone have a solution to this?
Same issue here
I have the same problem when I try to finalize the migration process. (sorry, for the semi-hungarian UI, it changed to this language automatically, and I cannot switch it back to English)
Please, let me know how I can finish the process.
Thanks,
Peter
