Dear guys,
I want to buy a single remote access licence, to be installed on my laptop and then I will user my mobile to access to it.
What licence should I purchase? It is possible? Thank you for your reply.
Hello @GPHAM Welcome to our Community and thank you for your first post! 🌏️ To answer your question on using a mobile device such as an Android or iOS as a starting point, yes. You can use a mobile Android or iOS device to remote into standard computers just fine. If you wanted to remote into a mobile device, that is a different story. That would require a Mobile Device Support Add-On license. As for which license you should get specifically, each of our licenses supports using a mobile device as a starting point, so for a recommendation, I suggest contacting our Licensing Department via any of the contact methods listed in the link below. They will ask a few questions, and make sure we get you on a license that fits your needs. https://www.teamviewer.com/en-us/global/contact-sales/ Let us know how it goes and if you need further help. 👍️
Thank you so much
See what's new at TeamViewer
