After installing and running teamviewer we get a segmentation fault error, we did not have this with v15.62.4, is it still possible to get this older version?
Please add a comment when the newest version will work again.
We use v15.62.4 now, and this one works ok
Same problem. Did you found the older version. The problem seems to be in 15.64.3 too.
Same problem. Did you found the older version? The problem seems to be in 15.64.3 too.
I disabled automatic update. Please let us know when the problem will be solved to start the update again.
Found this link. I don't know if it's only the Host version.https://dl.teamviewer.com/download/linux/version_15x/teamviewer-host_15.62.4_armhf.deb
See what's new at TeamViewer
