How to connect to someone else's computer
Hi @m_teplo,
Thank you for your post in the TeamViewer Community 😊
We're happy to assist you get started with TeamViewer! To begin, please check whether both your local device (the one initiating the connection) and your remote device (the one being accessed) are supported by TeamViewer: Supported operating systems for TeamViewer
Once compatibility is confirmed:
💡 If you're unsure which module to choose, the TeamViewer Full Client is a versatile option—it supports both outgoing and incoming connections.
To guide you through setup and starting remote sessions, please refer to the article: Get started with TeamViewer Remote
If you need more specific guidance, please let us know the operating systems of your local and remote devices. 😀
Chisa
