Not only teamviewer12 but also any previous version doesn't show any kind of GUI
I solved upgrading Wine to the 2.18 version with staging pathes.
Thx a lot
Iade
I had the same issue on Gentoo.
Two things to make sure:
1. run "tv-setup checklibs" from inside the teamviewer folder, this checks if all required libraries are in place. On Gentoo, you have to manually install some 32bit versions.
2. Teamviewer/Wine doesn't run with freetype > 2.8. If you have the current ~ version installed (2.8.1), it won't open the GUI. A downgrade will solve this.
So this goes to the devs here: This is probably a wine issue. Can we expect a TV version which is compatible to a recent freetype lib?
Cheers,Daniel
Dear iadegesso,
Thank you for contacting TeamViewer.
To be able to troubleshoot your issue, May you please describe your system.
Please include if you're using X or WayLand, Display Manager and Desktop Environment.
This information will help us understand better your issue.
We are looking forward to your comments.
Christian
See what's new at TeamViewer
