You've just finished helping a colleague with an issue on their office computer; the problem is resolved, you've closed the remote session, and you have both moved on to other tasks. The catch? Neither of you is anywhere near the remote device.
In moments like this, it's easy to wonder whether that computer is still sitting unlocked. Fortunately, TeamViewer Remote can handle that automatically.
One of TeamViewer's most overlooked security features lets you automatically lock the remote computer when your session ends, helping keep devices secure without requiring an extra step from you or the person you assisted.
What this feature does
When enabled, TeamViewer automatically locks the remote computer as soon as you disconnect from a remote session.
That means:
- The device is secured immediately after your work is done.
- No need to remember to lock the computer manually.
- Sensitive information remains protected.
- Shared office devices are less likely to be left accessible unintentionally.
It's a simple setting that quietly adds an extra layer of protection to every remote support session.
Where this feature shines
Imagine you're troubleshooting a colleague's payroll application in another city. After resolving the issue, you disconnect and continue with your day. Your colleague is away from their desk attending a meeting, and no one is available to lock the device.
Because the automatic lock setting was enabled, the computer immediately returned to the lock screen when the session ended. No follow-up message. No extra reminder. No need to wonder whether the device is still exposed.
How to enable it
You can enable this feature globally so it applies to all future remote sessions.
Enable it in TeamViewer settings
- Open TeamViewer Remote.
- Go to Settings.
- Select Advanced settings.
- Locate Lock Remote Computer in the Advanced settings for connections to other computers section.
- To enable for all connections, set the drop-down to Always.
Once enabled, TeamViewer will automatically lock supported remote devices whenever you disconnect.
Enable it during an active session
Need it for a specific device only? You can also enable it while connected to a remote computer.
- Start a remote session.
- In the remote session toolbar, select Actions.
- Locate Lock and then select Lock on session end.
- Enable the setting.
- Continue your work as normal.
When you end the session, TeamViewer will automatically lock that device.
One less thing to remember
The best features aren't always the ones front and center. Sometimes they're the ones that quietly remove a task from your mental checklist.
Automatic locking helps you:
- End sessions with confidence.
- Follow security best practices consistently.
- Reduce the chance of leaving a device unattended and unlocked.
- Spend less time thinking about post-session housekeeping.
It's a small adjustment that can make every remote connection feel just a little more seamless.
Give it a try
If you regularly connect to office workstations, shared computers, or devices containing sensitive information, this feature is well worth enabling. You may never notice it working, and that's exactly the point. The next time you wrap up a remote session, TeamViewer can handle the final security step for you.
If you've already been using this feature, we'd love to hear how it fits into your workflow and in which situations it's made a difference. Share your experience with the TeamViewer Community and help others discover one of TeamViewer Remote's most useful hidden gems.
