I found the reason why my teamvewier stops working. Screen can be shared BUT the android device can't be control. The reason is because the add-on stopped working.
To get it working again. I need to access the app section. select "force stop" and select "clear all data".
Then I need to "accessibility"→"downloaded apps", turn off. Read the warning and turn back on. (if I don't stop the app and clear cashe there is a message saying its malfunction)
I hope teamviewer can fix this issue. The add-on and host is running in unrestricted battery mode.
