Signing in to TeamViewer on a new device has always required an additional layer of security: adding the device itself as a ‘Trusted device’, which then allows your login credentials to be utilized locally. But here’s a handy option you might have overlooked: did you know you can approve the device right from your smartphone with a push notification?
No need to switch over to your inbox and look for the trusted-device email. Once the request is confirmed in the app, you can log in and start making your connections!
Put trusted device requests in your pocket
With the TeamViewer Remote Control app installed on your phone, signing in on another device can trigger a Sign in request notification directly within the app! Open it, review the device information, choose how you want to trust the sign-in, and tap Trust.
You can choose:
- Trust this device to add the device as a trusted device.
- Trust this IP address to trust the IP address.
- No, trust only once if you only want to approve that particular sign-in.
On Android, you can even trust the device directly from the notification!
Set it up
Before you start, make sure:
- The TeamViewer Remote Control app version 15.35 or newer is installed on your smartphone.
- You’re signed in to your TeamViewer account in the app under Computers.
- Push notifications for trusted devices are enabled under Settings ➜ Account.
Then, the next time you need to trust a device:
- Sign in to your TeamViewer account from the TeamViewer client or the web client.
- Tap the Sign-in request notification that appears on your smartphone.
- Check the device information and select Trust this device, Trust this IP address, or No, trust only once.
- Tap Trust.
Missed the notification when it appeared? You can retrieve it from your phone's Notification Center.
Skip the inbox detour
The nice part is how little interruption this adds to signing in. Instead of opening your email and finding the trusted-device request, the approval can come straight to the phone that’s already with you.
Once you've approved the request in the TeamViewer Remote Control app, you don't need to approve the separate trusted-device email.
It’s a small feature, but exactly the kind that’s useful to know about before the next time a Trusted Device prompt appears.
Have you had a chance to try this feature out? We’d love to hear about it if so!
