On one computer the Computers & Contacts panel appears every time Windows boots. Of the dozen or so computers I know that have TeamViewer installed, only one exhibits this behavior. Is there a way to prevent this from happening?
Perfect. That solved the problem. :smileyhappy:
Hi ScottDF,
Could you please check the following TeamViewer settings on your device?Extras --> Options -->Advanced (Show advanced options)
Advanced Settings for Computer and ContactsHere you can add or remove checkmark for the option Show Computer & Contacts on startup
:smileyhappy:
I have the same problem. I couldn't find any solution......
I have latest build. Tride everything but without luck. Strange.
Interestingly enough, It is checked off on my computer and DOES NOT show up for me... ODD... The other error you are receiving I've seen before, But I can not remember what they said caused it. I'm pretty sure it was fixed in a release a few months ago though. Have you tried updateing your TeamViewer to the most current build?
I have same issue despite I unchek that option. Every time I start TW its keep showing.
Also some script error shows every time I close TW. Tried to reinstall it few times but problem stays (and above issue too).
See what's new at TeamViewer
