I have a few users who turn their TV off when first booting up their PC's. Am I able to prevent them from doing this so that TV is always active ?
Yes, this is easily possible. There are two options which should do the trick.
In TeamViewer options under advanced scroll down to the bottom and select both marked checkboxes:
Many thanks. :smileyhappy:
