Hello All,
I exedentlly delete a shared contact folder.
is it possible to restore it ?
thanks,
Thanks for posting
Unfortunately no, there is no way to restore deleted items.
However, it is not possible to delete a group with anything in it.EXCEPT - If the group was not owned by you, but instead shared to you by another user (Identifiable by a white cloud next to the group) then you can "Delete" the group from your list even if it had items in it.
If the case is it was a shared group, then the group has not really been deleted, just Un-shared with you. The original owner can share this with you again in this case.
-Scotty
See what's new at TeamViewer
