Hello, does Blizz provide a "test meeting", so participants of the real meeting can test their setup (installation, audio, etc) ahead of the real meeting? Kindest regards, HJ Bigalke
Hi HJ Bigalke,
you can set up a test meeting in advance with the potential participants to test the setting. Just use the same setting in the real meeting later. There's no "test meeting" feature available at the moment (if this is what you meant).
I hope this helps.
May I ask what your idea is behind the question?
Kind regards Wolfram
