II am trying to get to the teamviewer website however I keep receiving this message. I have used both Google Chrome and Microsoft Edge but neither seem to let me access the webpage.
Can someone please help me?
Thanks Maxwell
I found this issue is caused by TalkTalk Scamblock service. You have to phone them to get it turned off. If you go into your TalkTalk myaccount/myservices/homesafe settings and try to turn off Scam Protection it gives what is probably the standard customer services number. You then spend an age fighting the annoying automated robot and eventually get to somebody who will with any luck eventually turn it off. The bloke I ended up with took repeated attempts to do so before it showed as off my end and teamviewer worked.
TT mention it's done via their DNS so I changed to Google public DNS on the router it case it reappears some time later as there are mentiond of this going back to 2016 which say TT removed the block.
Hi Maxwell,
Thank you for providing the links.
We cannot reproduce the issue but I can assure that the security certificates are valid and up to date.
Is it possible that your date on the device is not set correctly? Which date is it showing in your tray menu (probably in the lower right corner of your device)?
Can you reach the site when setting the date on today (6th March, 2018)?
Thanks, Esther
tried all different links:
https://www.teamviewer.com/en/download/windows/
Hi @MaxwellSummerfi
Can you send me the exact link you tested?
See what's new at TeamViewer
