I have updated my OS and lost the ability to use the app on High Sierra. I presume this is because I am only allowed to use two devices.
I cannot find where to change them over and 2 emails sent to support unanswered.
Can someone help? Thanks
Hi Flight4,
You just need to sign in to the software with your TeamViewer account.
Your license will follow your TeamViewer account. Simply sign into the software with your login to use the license. You can use the license from up to 3 devices total.
If you already have 3 devices registered, you will be directed online by the software to remove one of the existing devices from your license.
You can also remove the devices by logging in directly here where you can deactivate an existing device.Once you have removed a device, you can sign in to a new device as normal.
Hope this answers your question!-Scotty
See what's new at TeamViewer
